coolent leaking
  • 4 weeks later...
Do a leak test by yourself, and see if its DIY or something major.
Check radiator bottle for leak, check all the plumbing to and fro from engine to radiator and then radiator to expansion bottle. Then check the radiator and if its radiator leak then you def need external assistance, other two you can DIY. Good luck.
