enaam Posted June 1, 2012 Share Posted June 1, 2012 When should i top up the engine oil? should i fill it up to the Mark every time i see its going a bit low or should i be waiting till it reaches the add oil Marking the LOW one. Link to comment Share on other sites More sharing options...
sanjayl Posted June 2, 2012 Share Posted June 2, 2012 If you think its going low then it must be leaking your first concern should be fixing the leak and what you are asking if you should wait till it reaches low to top up then now you shouldn't but also dont ever over fill it too. Link to comment Share on other sites More sharing options...
Dollabill Posted June 11, 2012 Share Posted June 11, 2012 I like to make sure the oil level is about three quarters full when cold so that when it heats up it expands to nearly top level. It doesn't matter how frequently you add, unless it's obviously leaking, although Hondas will burn a bit of oil with hard use. Just make sure it never gets dangerously close to the bottom nick on the dipstick and you should be fine! Good Luck! Link to comment Share on other sites More sharing options...
dasautoservices Posted July 27, 2012 Share Posted July 27, 2012 Honda recommends 5000km or 3months whichever is coming first Link to comment Share on other sites More sharing options...
