jatin Posted March 17, 2014 Share Posted March 17, 2014 Hey guys Just wanted to know, how does the temperature outside the car affects the AC in the car? Thank you Link to comment Share on other sites More sharing options...
adil Posted March 18, 2014 Share Posted March 18, 2014 Very interesting topic. Generally people face problem in the AC specially when its summer. The compressor of the AC gets overheated because of the hot temperature which results in the level of refrigerant going down. So it is always advised to maintain the level of refrigerant in the car by proper maintenance of your car. Link to comment Share on other sites More sharing options...
Mach3 Posted April 17, 2015 Share Posted April 17, 2015 If the temperature outside is very high (and this happens quite often in UAE:) ) AC in certian car models will experience some difficulties mostly about the moment when they start to cool properly. Link to comment Share on other sites More sharing options...
Ak Posted November 17, 2016 Share Posted November 17, 2016 Its not the compressor which is getting hotter in summer and u face less cooling. It is because in high temperature you can not shift heat easily from inside of the car to out side of the car via condensor (heat exchanger). Many models have super design and this heat is not a problem , but some make and models really perform bad in summer. Properly cleaning the fins can increase the cooling better. Regards 1 Link to comment Share on other sites More sharing options...
Derick Posted November 18, 2016 Share Posted November 18, 2016 17 hours ago, Ak said: Its not the compressor which is getting hotter in summer and u face less cooling. It is because in high temperature you can not shift heat easily from inside of the car to out side of the car via condensor (heat exchanger). Many models have super design and this heat is not a problem , but some make and models really perform bad in summer. Properly cleaning the fins can increase the cooling better. Regards Hmm, this is really interesting to know that to fix this borderline cooling issue we need to upgrade the condenser and not the compressor.....! Am I right? Link to comment Share on other sites More sharing options...
Ak Posted November 18, 2016 Share Posted November 18, 2016 Generally speaking yes. even condensor can be converted to water cool for better cooling. But there are other things to tackle. Mechanical fitting of new condensor High air flow for bigger condensor Matching of peessure losses That is the reason i said some car designs are superb as they properly maintain super heat and sub cooling. while other cars just maintain fuel ratio only. Same bad car will give u superb cooling in winter with the same compresor because it can reject heat easily in winter time. With kind regards. 1 Link to comment Share on other sites More sharing options...
