bombman Posted May 10, 2012 Share Posted May 10, 2012 It just happened that which i started my Alleoad the there was nothing no click nothing. i turned the key more the 10 times but i was not successful in starting the car. i am in desperate need of some advise as to what can be a quick fix to at least drive to a good mechanic or if i can fix this myself as i m not worried to plunge in if i can do it myself. just need the guidance Link to comment Share on other sites More sharing options...
warzi Posted May 16, 2012 Share Posted May 16, 2012 the battery seems to have died. getting a new one is what can solve your problem dont rotate the keys so many times it will spoil the self. Link to comment Share on other sites More sharing options...
kabir Posted May 24, 2012 Share Posted May 24, 2012 have you checked the alternator that charges the battery. If that is good that check the fuel pump if its working well. If the car is not working then its not always the battery. Link to comment Share on other sites More sharing options...
abbaz Posted May 29, 2012 Share Posted May 29, 2012 call for a recovery and take your car to a good mechanic im sure he will diagnose it correctly. Link to comment Share on other sites More sharing options...
