Noise when in steering full lock
It could be due to various causes, from something like a loose fender inner shield which maybe rubbing against your tyre or even worn out steering joints
  • 3 weeks later...
Start the engine and keep the gear on park “P” position and steer the wheels in both direction if the sound is coming it’s about the power steering fluid and pump since it is speed adaptive check fluid level and condition and the mesh in the fluid reservoir and finally the pressure valve which is integrated in the fluid pressure hose (the big screw with spring and metal ball inside it)
There is 2 type electrical and normal mechanical runs with the engine depending on the model 4,6 or 8 cylinders
