hankpank Posted August 10, 2012 Share Posted August 10, 2012 As in this section i have read everything and i want to change the Speakers both the rear ones dont know how to do that. Can i get a DIY on how i can do that Link to comment Share on other sites More sharing options...
taaj Posted August 14, 2012 Share Posted August 14, 2012 buy new speaker unscrew the panel or cover slowly pull it out making sure that u are gentle as the wires are very delicate and my brake off. remove the wires and install the new speakers. Link to comment Share on other sites More sharing options...
anje Posted August 16, 2012 Share Posted August 16, 2012 I suggest let the professionals do this job for you as there is wiring involved and if you have never done this you may brake something. Link to comment Share on other sites More sharing options...
danish Posted February 19, 2014 Share Posted February 19, 2014 To remove the rear speakers is a big job because it solely depends upon how the rear speakers are fixed in the car. If it is permanently fixed with the bolts, then its better you take professional's help. But if you the rear speakers are only assigned to the rear dashboard, then you can remove it on your own. Just make sure that you don't destroy the wires as they are delicate. After detaching it, you can assign your new speakers and connect the wires back. I hope the information is helpful for you. Link to comment Share on other sites More sharing options...
