check gauge light problem
Please dont do drive with Engine oil light on
Your engine oil pump has failed and many components inside engine is running dry. May be the damage is already done or it will happen soon after you fix new pump. If you hear clanking noise from engine then that means crank main bearing or crank connecting rod bearing is fried due to heat as oil lubrication was missing.
It will be very unlikely if bearng are still fine. Only if as soon as you seen this engine oil light and stopped the vehicle.
