kenee Posted June 26, 2011 Share Posted June 26, 2011 my steering is difficult to move i changed the steering oil but still the same Link to comment Share on other sites More sharing options...
screamer Posted June 29, 2011 Share Posted June 29, 2011 there are a number of things to check. first u must see if the steering oil is leaking? if not the the belt that connects the engine's main drive pulley to the power steering is broken or not, and still if you don't find anything wrong check the power steering pump and finally the power steering rack. if any of the above is faulty then it could cause the hard steering. Link to comment Share on other sites More sharing options...
