Hyundai Maintenance Procedures - Common Additional Services
Hyundai Air Filter Replacement
The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms.
Hyundai Automatic Transmission Fluid/Filter Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms.
Hyundai Brake Fluid Replacement/Flush
Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage.
Hyundai Cabin Air Filter Replacement
Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms.
Hyundai Coolant Replacement/Flush
Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms.
Hyundai Differential Fluid Replacement - Rear
Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Hyundai Drive Belt(s) Replacement
Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms.
Hyundai Rotate Tires
It is important to rotate the tires from front to rear every 8000-12000 kms so that they wear evenly. This may not be possible on some vehicles because of directional tread design or rim size differences.
Hyundai Transfer Case Fluid Replacement
Transfer Case fluid breaks down and becomes contaminated with moisture over time and can lead to transfer case damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
  • 1 month later...
Dear Admin,
I bought an elentra, I like it but I didn't get any maintenance schedule for it neither the service contract
so I called the service center & they infomred me the 1st maintenance should be done at 1000 km
why don't you print the maintenacne schedule customized per each model mention the cost for each
  • 1 year later...
hi Ehab,
Im not from hyundai and I think Hyundai wont mind if I post the link to their site :) first 1000km is free of charge. I guess its for all cars. Then afterwards, services will be done for every 5000km. Major service i think is done for every 10000km. For the prices of maintenance service for succeeding mileage, please check this site
http://hyundai-uae.com/uae/services/service_contract.html
Its best to check with the service centers as the prices may not be updated. But at least ull get an idea of how much it will cost u.
  • 1 year later...
Hi members
When i went to get the car washed i noticed that there is a powder like substance around the car battery area. Not sure if the battery is damaged or the battery damaged something.
Will really like if someone can please advise.
  • Carnity unpinned this topic
