JagdeshK Posted September 24, 2013 Share Posted September 24, 2013 Guys, I wanna replace the car battery - the one original installed in sonata 2012 is Delkor 54MF-26GL 12V RC:1100MIN CCA:600A, Should I go for higher one or the same for better performance? and where can I get it? Thanks. Link to comment Share on other sites More sharing options...
mum65 Posted September 29, 2013 Share Posted September 29, 2013 Yes u can put upto 60A if u wish to. Cause i also used it in my sonata. But check out the size and all. But dont go for higher. Link to comment Share on other sites More sharing options...
hassano Posted October 4, 2013 Share Posted October 4, 2013 Jagdesh: Your car has 68 AMP battery that keeps 600 AMP as a cold cranking Amp. You can get any battery that is close to this spec. Major thing is it should have same or slightly higher AMP not lower. Secondly before buying make sure the size is same as your current one in terms of length and width. You can choose from trane, Solite, AC Delco etc. approx should be within 300 dhs. More importantly before changing call the dealer and see if this battery is covered under warranty as its less than 2 year old car. Link to comment Share on other sites More sharing options...
JagdeshK Posted October 6, 2013 Author Share Posted October 6, 2013 Thanks for comments - Well I have gone for AMARON with Specs 80D26L - 12V 60AH - CCA-500 a week before. No as you mentioned CCA should be either same or higher - SO would it impact on the performance in longer run? I'm really worried now Link to comment Share on other sites More sharing options...
