sanstev Posted April 22, 2011 Share Posted April 22, 2011 there was black smoke coming out of my exhaust and one of my friend suggested that i should get all the filters changed which i did but i am still facing the same issue now what should i be doing to stop this thanks Link to comment Share on other sites More sharing options...
trueguy Posted May 8, 2011 Share Posted May 8, 2011 Black smoke means unburnt fuel, and its major causes are as follows: Black smoke is caused when the mix of fuel and air becomes un-balanced. Normal mixture is 14.5 parts air to1 part fuel. When the fuel to air mixtures change because of a malfunction the mixture can go as high as 14.5 to 2 or 3, two to three times the proper amount. The black smoke is the excess fuel generated from the rich mixture and can be cause by one of the following: * Plugged Air Filter * Shorted or stuck fuel injector * Failed fuel pressure regulator * Vacuum leak * Shorted PCM Sensor Link to comment Share on other sites More sharing options...
