daved Posted April 27, 2012 Report Share Posted April 27, 2012 For some reason, the car seems to shake horribly from the rear. I already bought new alignment, new tires, I even replaced the bushings. I even took it to a mechanic but he said that everything seems to be fine. Does anybody have an idea what might be causing this? Link to comment Share on other sites More sharing options...
humsafar Posted May 1, 2012 Report Share Posted May 1, 2012 did u chck ur drive shaft. This is also one of the cause of shaking Link to comment Share on other sites More sharing options...
delfi Posted May 3, 2012 Report Share Posted May 3, 2012 Have you checked it it is a problem with the struts? I know that you mentioned that it comes from the rear but you might as well check it. Link to comment Share on other sites More sharing options...
daved Posted May 3, 2012 Author Report Share Posted May 3, 2012 Thank you very much everyone. I actually had it checked and apparently it had something to do with the alignment of the wheels. Link to comment Share on other sites More sharing options...
koono Posted May 10, 2012 Report Share Posted May 10, 2012 Is your car fixed now. if not you can go to very good service shop which i can guide you to. Link to comment Share on other sites More sharing options...
ClearSky Posted May 11, 2012 Report Share Posted May 11, 2012 My car only does this when I start driving over 90 I've only done it a couple of times but every time its scary as hell. Link to comment Share on other sites More sharing options...
