nadiya Posted May 30, 2011 Share Posted May 30, 2011 1996 BMW 318ti has a continuous screeching sound when the car is moving what could be causing this. i have checked the drive belt which is in good condition. what could it be then Link to comment Share on other sites More sharing options...
shaheen Posted May 30, 2011 Share Posted May 30, 2011 Check all brake pads, if its not touching the brake drum? Check all tires backside isnt rubbing against some plastic, heat shield, fender etc. Check AC fan belt, as its quite common and put some wd40 in belt if it stops the it means belt is running dry and its better to change before it snaps. Link to comment Share on other sites More sharing options...
