Vibration issues
Sounds like the vibration follows the turbo rev range. I always start my engine and let it run for a minute before setting off to circulate the oil to the bearings in the turbo and I always let it tick over before shutting off to cool the turbo. If you don't do this then bearing wear can be a problem.
