shehzaad81 Posted December 31, 2010 Share Posted December 31, 2010 my check engine light was on and i am told by the mechanic the at the radiator is cracked .so i went in for a second opinion as it was difficult for me to gulp it down and he said it is due to 2 plug wires being off burnt up the ignition coil.any advice on what could be the genuine problem Link to comment Share on other sites More sharing options...
nutbolt Posted January 6, 2011 Share Posted January 6, 2011 Ignition coil and radiator is actually stays POLES APART in discovery, exactly opposite to each other (very far). Mechanic is bull shitting. See someone else. Secondly if radiator is cracked, is there is any noticeable or fine leak have you notice or reduction in coolant level? If not DO NOT CHANGE THE RADIATOR. If yes, still get second opinion. Link to comment Share on other sites More sharing options...
vandom Posted October 31, 2012 Share Posted October 31, 2012 what are the other causes of getting check engine warning? Link to comment Share on other sites More sharing options...
nutbolt Posted October 31, 2012 Share Posted October 31, 2012 There are so many reasons to have check engine light. Some are serious like weak cylinder pressure in any of the cylinders, some are minor like plugs, ht leads etc. Better to get computer test done and that will read the exact fault code to pin point you in right direction. If there is no error code, ask them to clear this fault and you check if it happen again. Sometime loosely close fuel cap at petrol station can cause this to have check engine light too. Link to comment Share on other sites More sharing options...
octo Posted November 10, 2012 Share Posted November 10, 2012 2 days back faced the same issue and the warning went by itself. Link to comment Share on other sites More sharing options...
sqeer Posted January 9, 2013 Share Posted January 9, 2013 how much have you spend to fix radiator. Link to comment Share on other sites More sharing options...
shehzaad81 Posted January 20, 2013 Author Share Posted January 20, 2013 changed the radiator. Link to comment Share on other sites More sharing options...
