haimant Posted July 11, 2011 Share Posted July 11, 2011 my range rover has a sudden loss of power when accerlating it is very sluggish it doesnt matter if the engine is cold or warm. As soon as i step on the petrol it seems to be clogged. I have error messages that was showing misfire on #2, 4, and 7. the engine oil pressure sensor high voltage input is high that is greater than 4.5 volts. what should i do Link to comment Share on other sites More sharing options...
iroc Posted July 12, 2011 Share Posted July 12, 2011 Is it a p38 or a later model range rover? When was the last time spark plugs were changed? If there are misfire fault codes on specific cylinders then try swapping ignition coils / plug wires to see if the misfire shifts. Link to comment Share on other sites More sharing options...
bmwdoc Posted July 19, 2011 Share Posted July 19, 2011 do Exactly as Iroc has told you then come back with your findings. Link to comment Share on other sites More sharing options...
