How do i change the alternator of my 2005 LR3?
Removing the alternator
Part one :- Disconnect battery and remove accessory drive belt. then remove 2 bolts securing generator to mounting bracket.
After releasing generator from mounting bracket remove nuts securing generator leads, and release leads.
Now remove generator from mounting bracket and remove pulley from generator.
For installing the alternator
Part Two:- Installation is reverse of removal procedure and tighten nuts and bolts to specifications.
  • 1 year later...
  • 2 weeks later...
i have got encouraged to do this myself. very nicely explained.
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
thanks this was a very well explained procedure.
  • 2 weeks later...
