gagger Posted September 14, 2011 Share Posted September 14, 2011 there is some impurities on the Engine Oil and so i drain the oil and refill it with fresh oil but the same thing repeated. How can i solve this. Link to comment Share on other sites More sharing options...
bmwdoc Posted September 15, 2011 Share Posted September 15, 2011 couple of questions: are you also changing the oil filter? What are these impurities, it could well be water which means your head gasket is on the way out? also which oil make and grade are you using? Link to comment Share on other sites More sharing options...
