VCO Posted January 8, 2012 Share Posted January 8, 2012 Has anyone tried to plug an OBD2 scanner to a Disco 1 ? I tried but it did not work with my Disco . I don't know if its my scanner or the port or Disco 1s OBD2 compatibility has anyone tried ? Link to comment Share on other sites More sharing options...
walther75 Posted January 8, 2012 Share Posted January 8, 2012 Hi VCO, I have a Nanocom, we can check at one of the next drives. One Life - Live It! Defender 90 TD5 Link to comment Share on other sites More sharing options...
VCO Posted January 8, 2012 Author Share Posted January 8, 2012 Hi VCO, I have a Nanocom, we can check at one of the next drives. perfect we are really a resourcefull group Link to comment Share on other sites More sharing options...
walther75 Posted January 8, 2012 Share Posted January 8, 2012 Thats what it's meant to be One Life - Live It! Defender 90 TD5 Link to comment Share on other sites More sharing options...
bmwdoc Posted January 9, 2012 Share Posted January 9, 2012 The OBD 2 is for GM cars so wont work on LR Link to comment Share on other sites More sharing options...
Ghassan Posted January 9, 2012 Share Posted January 9, 2012 I suggest you Change the car and try it if it works if yes keep the new car LOL!!! Link to comment Share on other sites More sharing options...
VCO Posted January 9, 2012 Author Share Posted January 9, 2012 I suggest you Change the car and try it if it works if yes keep the new car LOL!!! Sounds good I think its not for GM only in fact all the cars sold in US from 94 onwards should have OBD2 as a standard I have read that V8 3.9 99 00 Disco 2 's support OBD. its limited but still supports you can see the temp of engine coolant, gearbox and some other info from ECU and reset some basic things but I do not have definitive answer for Disco 1 lets try on other cars and see what happens Link to comment Share on other sites More sharing options...
chiraag Posted January 14, 2012 Share Posted January 14, 2012 Discovery 1 is OBDII compliant, but you need a different adapter to plug the diagnostic system. X Launch 321 has all LR related adapter in the case, so get the check from guys who check LR with X Launch. I got same checked in my older 1998 RR last year from Aweer emarat, they have PITCO service center and this guy plugged X Launch and scan my whole ECU. Cheers Chiraag Link to comment Share on other sites More sharing options...
