Known problems of Range Rover 2005 or 2006 model
udyan
Good choice already dear, supercharged are slightly more prone to issues than sport and HSE.
Just check if EAS is working fine and adjusting height properly and as fast as possible. If its slowly rising then and continue adjusting then there could be some minor to major bugs in EAS.
Check for no warning light on dashboard. Car drive well and stable above 100 km. Look for leaks under the car, minor leaks are acceptable but if something is really too much then i would advise to be careful and put hand after proper check from good workshop.
In case you are wondering, EAS is Electronic Air Suspension. One of the best feature of Range and also prone to problems as it needs good care after every 2-3 years. It lifts and lower ride height as per user instruction and also as per terrain.
