saifrr Posted March 22, 2014 Share Posted March 22, 2014 Hey guys Please share the common causes of coolant thermostat troubles. Also, what trouble codes do we receive in such a case and how to diagnose the same? Link to comment Share on other sites More sharing options...
alex45 Posted March 23, 2014 Share Posted March 23, 2014 Whenever the thermostat stick is shut down, it causes the engine to overheat. And whenever the engine is overheated because of abnorml operating temperature, it pops up the trouble code of coolant thermostat. Link to comment Share on other sites More sharing options...
saifrr Posted March 23, 2014 Author Share Posted March 23, 2014 Thank you Alex. That was really helpful. can you also tell me how to fix problem? Link to comment Share on other sites More sharing options...
alex45 Posted April 1, 2014 Share Posted April 1, 2014 to fix it, one needs to check the temperature. You can use the thermometer to check the exact temperature in the thermostat. If its boiling, you need to replace the thermostat because it can be internal oil leaking. Link to comment Share on other sites More sharing options...
