kaz Posted August 11, 2011 Share Posted August 11, 2011 Hello to the Forum guys, i have found a lot of constructive answers to my questions in this form so i would like to thank you gust for starting this Dubai based thing Now come the question for which i want some advise. I want the specified low and high pressures for the air conditioner. When the air conditioner was not working properly I added some R134A to the system. When the outside temp was 36 degrees © and the low sided would not go above 40 lbs while the high side went to 200lbs. Now when the car runs it is idling very high and it smells like the compressor is burning up. I have been unable to find the specified low and high pressures. Also, how can i adjust it for the outside temperature? Link to comment Share on other sites More sharing options...
doney Posted August 15, 2011 Share Posted August 15, 2011 The low side has to be from 18-27 psi and the high side: 205-250 psi Link to comment Share on other sites More sharing options...
