santoddc Posted October 9, 2013 Share Posted October 9, 2013 i feel a shaking maybe missing my car while the engine on and not moving time.. please help Mazda6 (2006) Link to comment Share on other sites More sharing options...
vinayrai Posted October 13, 2013 Share Posted October 13, 2013 If car is well serviced in time, then its due time to check the car spark plug, HT leads and coil first and then check the fuel filter and fuel pump for any blockage or slow delivery of fuel. If its only shaking and not mis firing then check the engine mounting that may be cracked and causing this slight vibration in neutral, in that case it might also cause some jerk when you shift to gear from neutral. Link to comment Share on other sites More sharing options...
santoddc Posted October 19, 2013 Author Share Posted October 19, 2013 Thanks Vinay, i have already put my vehicle in Dynatrade, Abudhabi. Hope they can fix it only if it is affordable for me Link to comment Share on other sites More sharing options...
