franciswither Posted April 23, 2011 Report Share Posted April 23, 2011 2010 GLK brake lights need to changed can i do it my self or do i need an expert if i can i would appreciate if somebody can post me the steps thank you Link to comment Share on other sites More sharing options...
sonu Posted May 9, 2011 Report Share Posted May 9, 2011 1 Open the trunk. Locate the rear light assembly service cover that covers the back of the light assembly. The covers are located at the rear corners of the trunk. Remove the two retaining screws. Remove the cover. 2 Remove the three retaining bolts that hold the rear light assembly. Slide the assembly rearward and outward from the car. 3 Locate the socket for the defective bulb. Grasp the socket from the back of the rear light assembly and turn it counterclockwise until it releases. Pull the socket out of the assembly. 4 Push the defective bulb into the socket and turn it counterclockwise until it releases. Pull the bulb from the socket. 5 Insert a new bulb and reassemble the vehicle by following the steps in the reverse order. Link to comment Share on other sites More sharing options...
