bhorah Posted May 25, 2011 Share Posted May 25, 2011 i am a owner of S40 1995 Merc. and the big problem with my car is that it is loosing power of which i got a new battery installed but the problem remains so upon having my car battery tested,I was informed that I have a high output voltage reading.now wat Link to comment Share on other sites More sharing options...
billal Posted May 27, 2011 Share Posted May 27, 2011 Battery has nothing to do once your car is started. Even if you remove the battery wire after starting the car it wont stop and you can drive the car forever without switching off. Guy who sold you the battery may be made fool out of you. Im sorry. And dont listen to same guy anymore may be next he will ask you to repair the alternator for more voltage reading. Its all BS crap. Instead im more than likely that your any of spark plug must have gone bad and need change. If not check air filter is clean or need a change. Check the ignition coil is healthy and delivering enough spark. Check the fuel filter isn't choked and fuel pump is sending fuel at enough pressure. check above said things in same order and you will solve your problem faster. Link to comment Share on other sites More sharing options...
