naison Posted August 15, 2011 Share Posted August 15, 2011 I noticed that the hand break of my car is not working when i was on a uneven road and i pulled the hand break to leave my leg off the wheel break but the car still did not stop. what should i do, what should i fix. Link to comment Share on other sites More sharing options...
kumar Posted August 26, 2011 Share Posted August 26, 2011 Hand brake power cant replace the foot brake as they are manual brake and your foot brake is hydraulic one (100 times more powerful than handbrake). If you still think its loose and less powerful than before, try getting it adjusted from any mechanic. Behind the rear differential there is adjuster bolt that need to be tighten more. Link to comment Share on other sites More sharing options...
naison Posted February 12, 2013 Author Share Posted February 12, 2013 thanks bro this helped. i have to change the gear box where can i find a original from. Link to comment Share on other sites More sharing options...
