gabriel Posted February 3, 2014 Share Posted February 3, 2014 Hi fellas, I am thinking of buying 2006 model SLK for 70% for my wife and 30% i will drive. Wanted to know some known problem or possible technical issue with this year model after 7 years? Though I am on shoestring budget, but if i get good deal then i might upgrade to 2007 (chances are slim), so wanted to know if there is any big difference in 2006 or 2007 which makes it worth the stretch or i am good with 06 model within in my reach? Any help is highly appreciable guys. Thanks in advance. Link to comment Share on other sites More sharing options...
adnanJ Posted February 4, 2014 Share Posted February 4, 2014 2006 - 2007 is almost same unless you want upgrade a year. However in SLK what matters the most is engine size, stay away from 200 (if you can afford) go for 280 and above, they are more well built and less prone to problem. I had SLK 200 and was not at all happy with inferior build quality and AC failing on every summer in Dubai. My friend has 280 and it still runs fine in peak summer. Link to comment Share on other sites More sharing options...
