powerfool Posted November 11, 2010 Report Share Posted November 11, 2010 hi i am having a Mitsubishi Chariot Grandis 2004 model which has suddenly SRS warning light on,I tried disconnected the battery overnight but still the same. i dnt knw what is wrong. pls. help Link to comment Share on other sites More sharing options...
davidg Posted November 11, 2010 Report Share Posted November 11, 2010 SRS means that there is some issue with airbag. Check all fuses and relays esp one that mark SRS on it. might be some fuse is blown out and thats why SRS is deactivated and showing you light. if not then get urself SRS sensor checked from professional, may be due to age its faulty and you need new one to properly record an accident imapct to open the airbag for you. Link to comment Share on other sites More sharing options...
