shaha Posted January 8, 2011 Share Posted January 8, 2011 today morning when i switched on my car there was an indication on code PO455 what dose this stand for. please advice. thanks Link to comment Share on other sites More sharing options...
lenon Posted January 11, 2011 Share Posted January 11, 2011 Its Evaporative Emission Control System Tank Detected (gross leak) Causes A code p0455 most likely means one or more of the following has happened: * A loose or improperly affixed gas cap * A non-conforming gas cap (i.e. not factory/original brand) * Other leak or damaged piece in EVAP system Possible Solutions With a p0455, the most common repair is to: * Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back. * Otherwise, replace the gas cap, and/or * Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary Link to comment Share on other sites More sharing options...
