MitsubishiDxb Posted August 27, 2011 Share Posted August 27, 2011 Mitsubishi Maintenance Procedures - Common Additional Services Mitsubishi Air Filter Replacement The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms. Mitsubishi Automatic Transmission Fluid Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms. Mitsubishi Automatic Transmission Fluid/Filter Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms. Mitsubishi Brake Fluid Replacement/Flush Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage. Mitsubishi Coolant Replacement/Flush Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,000 kms. Mitsubishi Fuel Filter Change The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to performance problems and early fuel pump failure. It should be replaced at the mileage interval recommended by the vehicle manufacturer. Mitsubishi Manual Transmission Fluid Change The Manual Transmission fluid breaks down and becomes contaminated with moisture over time and can lead to transmission damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Mitsubishi Spark Plug Replacement Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval. Link to comment Share on other sites More sharing options...
walish Posted October 21, 2012 Share Posted October 21, 2012 i read that Fuel filter should be changed according to the manual but i dont have one and i dont know when to change the fuel filer. What do i do now Mitsubishi Pajero 1999. Link to comment Share on other sites More sharing options...
raaju Posted October 23, 2012 Share Posted October 23, 2012 get the filter changed when getting Major service done. Link to comment Share on other sites More sharing options...
sagar Posted October 26, 2012 Share Posted October 26, 2012 in my knowledge all filter should be changed in major service. Link to comment Share on other sites More sharing options...
farhankhalid Posted December 31, 2013 Share Posted December 31, 2013 Dear Mitsubishi Pajero Owner's I have the whole 'Workshop Repair Manual' for Pajero which cover all the models from 2007 to 2013 models. This includes procedures step by step guidance, with step by step Removal & Installation, Trouble Codes which is difficult to understand & how to repair what to repair, This Mitsubishi Repair Manual Covers complete Petrol Engine, Diesel Engine, Automatic & Manual Transmission, Transfer Case, Periodic Maintinance, Specified Lubricants, Parts & Sensors location, Body Repair etc. I can also help you out for reasonable Pajero used Parts, Wheel Rims, Body Parts, Used Tires etc etc. You can contact me through this website i can get back to you. Thanks Link to comment Share on other sites More sharing options...
