emaad Posted March 27, 2012 Report Share Posted March 27, 2012 motor of the rear wiper is jammed i dont know how to fix it. can anyone help? Link to comment Share on other sites More sharing options...
thakkar Posted March 31, 2012 Report Share Posted March 31, 2012 Get the motor checked and changed if not working Removal & Installation of the wiper motor Turn wipers on. when blades are vertical switch off the car. Unplug wiper motor connector and remove right wiper arm and blade. remove the negative battery cable remove right pivot nut and allow linkage to drop into cowl. Remove linkage access cover. access cover opening and unsnap wiper motor clip. Push back the clip from linkage until it clears nib on crank pin and remove clip. Disengage wiper linkage from motor crank pin. Remove wiper motor retaining screws and motor. install the motor in reverse. Link to comment Share on other sites More sharing options...
