how to change the heater hose?
parbon
  • 5 months later...
its a very simple procedure and if you have had your hands in such thing it will not be difficult.
First place a bucket below the the radiator and drain the system by opening the petcock fitting near the bottom.
Remove the clamps from your old hose with a pliers or screwdriver it will be a bit hard as with time they get very hard to remove.
Remove the hose and clean it, then apply a small amount of gasket sealer to the fittings to assure a tight seal with your new hose.
Slide new set of clamps onto the hose and install them
Tighten all the clamps, fill the radiator with coolant, and start the engine to check for cooling system leaks.
best of luck
