nunu Posted April 16, 2011 Share Posted April 16, 2011 when breaking the car jerks as this has been happening for quiet sometime and it has increased with time it has been a major concern pls. advice what should i do to solve the issue thanks Link to comment Share on other sites More sharing options...
sami Posted April 16, 2011 Share Posted April 16, 2011 In hard braking at high speed if it jerks, it means an ABS is activating to prevent vehicle from skidding. In softer brake it shudnt. If its doing on softer brakes too, that means something wrong with your ABS thinking process and better get the computer check to see what fauld code is recorded and why. Prefer authorized VAG system check as in general OBD tool you will get code but wont see the full detail of that code. Link to comment Share on other sites More sharing options...
