zahib Posted May 29, 2012 Share Posted May 29, 2012 the sudden response of braking is slowing down the the brake change warning didnt come up. should i change the brakes or should i wait for the warning sign Link to comment Share on other sites More sharing options...
shanky Posted June 1, 2012 Share Posted June 1, 2012 your brakes need to be changed. this is what i understand from your problem. its important to keep a constant eye on ur brakes as this is basic safety thing. Link to comment Share on other sites More sharing options...
rahuljones Posted August 9, 2012 Share Posted August 9, 2012 Or maybe your brake disc needs polishing and cleaning. Happened to me 2 times before I actually changed the brake pads. Link to comment Share on other sites More sharing options...
daniell Posted August 26, 2012 Share Posted August 26, 2012 the setting of the brakes if changed can also do the job. Link to comment Share on other sites More sharing options...
mithoon Posted August 30, 2012 Share Posted August 30, 2012 how was the brake oil was it leaking? the less responsiveness of the brakes can happen if the brake oil is depleting. Link to comment Share on other sites More sharing options...
leonerd Posted September 2, 2012 Share Posted September 2, 2012 i have had brake problem same one as mentioned i had to get them changed and were not very expensive to get them changed. i have contact if anyone needs. Link to comment Share on other sites More sharing options...
rahuljones Posted September 2, 2012 Share Posted September 2, 2012 And just mentioning if you are getting your brakes pads replaced its better to replace brake fluid at the same time. I do that to my vehicles which is serviced and maintained outside the dealer. Link to comment Share on other sites More sharing options...
