carguy Posted March 1, 2014 Share Posted March 1, 2014 Hey Everyone Please share the common electrical problems you face in your Nissan car. And how you managed to troubleshoot the same. This will be helpful for other people as well who are facing some electrical problems in their car. Link to comment Share on other sites More sharing options...
ameens Posted March 3, 2014 Share Posted March 3, 2014 The most general electrical problems i faced in my car were: Blown fuse, headlight problems, power window not working and fuel gauge problem. For all the electric problems, the solution is to find the wiring circuit which is providing power to the same and fix the wiring. Link to comment Share on other sites More sharing options...
hisham Posted March 26, 2014 Share Posted March 26, 2014 I generally faced the problem with the battery terminal and alternator. Most of the times, the battery use to get failed because of corrosion. The only solution I had was to replace the battery. With the alternator, the voltmeter reading used to go very low as it was losing power. And s, replacement was the only option. Link to comment Share on other sites More sharing options...
