lobo Posted May 18, 2011 Share Posted May 18, 2011 my car is facing loss of power and i cant understand the problem. can somebody please give me alist of problem causing this thanks Link to comment Share on other sites More sharing options...
dima Posted May 20, 2011 Share Posted May 20, 2011 Check all the plugs, then fuel pump delivery is consistent. If not the engine head gasket is leaking and causing loss of power with excessive smoke too. Link to comment Share on other sites More sharing options...
207_gti Posted May 22, 2011 Share Posted May 22, 2011 is the check engine light on? the car might have switched to "limp mode" if it detected a problem such as a misfire, or if the timing has somehow been changed. best thing to do is to get urself an OBD-II scanner tool to check what kind of error codes come up from the car's ECU. that would make diagnosing the problem a lot easier ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
sajanr Posted May 23, 2011 Share Posted May 23, 2011 Check the engine oil, if its turn milky and coolant level is down you have bad news. Engine head gasket failure. Link to comment Share on other sites More sharing options...
