207_gti Posted February 15, 2012 Share Posted February 15, 2012 A turbo is a great way of getting more power from a car. But, a turbo is still a mechanical part, and as such can fail at any time. There are a number of reasons as to why a turbo can fail. In the case of Peugeot's 1.6 turbo (THP) engines; the absolute #1 reason for the turbo failing is that the oil feed for the turbo is rather small and lacks a teflon coating on the inside. The problem: When hot oil cools down it leaves a residue. what this means for a turbo is that over time that residue builds up until it completely blocks the inside of the turbo oil pipe. When this happens, the turbo cannot receive lubrication or oil cooling, and so will cease up. The solution: To replace the standard pipe with a braided stainless steel PTFE (teflon) coated hose. The hose has a slightly larger inside diameter than the standard pipe, and has the teflon inside which will prevent oil buildup. Cost is AED160 which you can send to me via Western Union, and I can send you the new hose via Aramex (cash on delivery) or at a meetup. I HIGHLY recommend these hoses, as a mere 160 Dirhams is much cheaper than the 10K+ it would cost to replace the turbo. ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
bajav Posted August 21, 2012 Share Posted August 21, 2012 Again good info bro. Link to comment Share on other sites More sharing options...
premnath Posted August 25, 2012 Share Posted August 25, 2012 good post but just out of curiosity how do you know so much about cars do u own a workshop. Link to comment Share on other sites More sharing options...
junaidh Posted August 25, 2012 Share Posted August 25, 2012 Well to me he sounds like a pro and educated Peugeot owner than mechanic owing a workshop. Correct me if i am wrong? Link to comment Share on other sites More sharing options...
207_gti Posted August 25, 2012 Author Share Posted August 25, 2012 Yup, I'm just an owner. I've had my fair share of trouble with the car, and only from that trouble could I gain experience. With that experience I was able to find out by experimenting and talking to some very knowledgeable people about how to fix issues, and what can be done to prevent those issues form happening again. So far, my car is producing 40% more power than standard; i'm still using the standard turbo and engine, and yet it has been absolutely trouble free for the last 60000kms proper care, maintenance, and a thorough understanding of how a car works will ensure that a car runs smoothly ADAPT Performance - Power Unleashed SOFTWARE TUNING & PERFORMANCE PARTS www.adaptperformance.com Link to comment Share on other sites More sharing options...
Indra Posted August 25, 2013 Share Posted August 25, 2013 Can this be use for 5008? The engine is also 1.6 turbo? Link to comment Share on other sites More sharing options...
