adnanz Posted September 29, 2013 Share Posted September 29, 2013 Anyone here know what a BSI RESET is? A lot of technicians/electricians use that option as the bsi control module is connected to everything electrical. The procedure for the reset is a little time-consuming but it apparently puts the control module back to factory specified settings. According to my information, a lot of peugeot faults can be traced back to this control module. Link to comment Share on other sites More sharing options...
mojoi Posted September 30, 2013 Share Posted September 30, 2013 What you are describing is consistent with a bad alternator. You should have to Al Naboodah and asked them to test the alternator after the second time you broke down. The guy who looked at your car the second time around simply took advantage of you and changed the battery hoping that you would go back to him with the same problem. It is normal for an alternator to fail internally. Agree with both jasim and saif. Take our word. Link to comment Share on other sites More sharing options...
