Cadillac Scheduled Maintenance Procedures
* Rotate and Inspect tires
* Inspect Accessory drive belt
* Inspect Accessory drive belt(s)
* Inspect Air intake system
* Inspect Automatic transmission fluid & filter
* Inspect Automatic transmission shift linkage
* Inspect Brake fluid, brake lines and hoses
* Inspect Brake hoses
* Inspect Brake linings
* Inspect Brake rotors, drums, pads, shoes
* Inspect Brake system
* Inspect CV-joint boots & axle seals
* Inspect Cooling fan operation
* Inspect Cooling system
* Inspect Cooling system hoses and clamps
* Inspect EVAP system
* Inspect Engine air cleaner filter
* Inspect Engine coolant and washer fluid
* Inspect Exhaust system & heat shields
* Inspect Fluid leaks
* Inspect Front & rear axle fluid level
* Inspect Front & rear driveshaft slip-yoke
* Inspect Front wheel bearings
* Inspect Front/rear axle fluid level
* Inspect Fuel filter
* Inspect Fuel system
* Inspect Parking brake system
* Inspect Power steering fluid
* Inspect Restraint system components
* Inspect Shields & underhood insulation
* Inspect Steering linkage
* Inspect Suspension and steering components
* Inspect Suspension components
* Inspect Throttle body mount bolt torque
* Inspect Throttle linkage
* Inspect Transfer case fluid level
* Inspect Transfer case shift lever
* Inspect Transmission fluid level
* Inspect Wiper blades
* Inspect/Clean Throttle body
* Inspect/Lubricate Body components
* Inspect/Lubricate Chasis and suspension
* Inspect/Lubricate Parking brake cable guides
* Inspect/Lubricate chassis & suspension
* Replace Air cleaner filter
* Replace Automatic transmission fluid & filter
* Replace Cabin air filter
* Replace Engine coolant
* Replace Engine oil & filter
* Replace PCV valve
* Replace Spark plugs
  • Carnity unpinned this topic
