susheel Posted February 1, 2011 Share Posted February 1, 2011 i would like to know if a cracked radiator can be repaired in my 2008 Catera. thanks Link to comment Share on other sites More sharing options...
james Posted February 10, 2011 Share Posted February 10, 2011 NOPE, you can run it for a while onm temp fix like leak sealants and all from ACE. But it wont hold for long. Better to get new asap or else u might end up frying the engine by chance. Link to comment Share on other sites More sharing options...
rushab Posted February 27, 2011 Share Posted February 27, 2011 Yes you can repair it, in shj you can get internal lines of radiator and keep the outside shell same as stock.With this you can change the part that was leaking and not buying whole radiator. Considering if urs is old caddy having metal jacket radiator, newer comes with plastic body (use and throw). Link to comment Share on other sites More sharing options...
