quinti Posted May 22, 2011 Report Share Posted May 22, 2011 the washer for the windscreen is leaking, the problem is that I do not know how to replace it. looking forward for your inputs Link to comment Share on other sites More sharing options...
mytouareg Posted May 24, 2011 Report Share Posted May 24, 2011 Check under the washer Jet that sits on hood. Underneath the hood there is hose that connect to jet from down, may be its loose or brittle and leaking water from there. Check the hose going to the washer fluid bottle and check its joint in the bottle if its leaking. Remove the washer fluid bottle outside and see if bottle itself is leaking. Link to comment Share on other sites More sharing options...
