service stability system
Your car has electronic stability program that kicks ABS and Traction control to compensate the loss of traction on lose gravel or on slippery watery surface. This system needs service or may be some part is not functioning properly, so better seek a good garage who can run computer diagnostic check and see what fault code leads to which component so that you can fix it.
  • 3 weeks later...
