bassim Posted August 3, 2014 Report Share Posted August 3, 2014 The accessory socket/cigarette lighter in my car is not working properly. How can I check the same? Please help me. Link to comment Share on other sites More sharing options...
rockytan Posted August 4, 2014 Report Share Posted August 4, 2014 To test the accessory socket, you just need the circuit tester and test light. There are two frames in the accessory socket. Attach the test light to the outer frame of the socket and the long end of the tester to the inner frame of the socket until it touches to the back. If the test light blows, it mean the fuse is ok. But if the lights don’t blow, then the fuse of your car is gone. You need to get it replaced Link to comment Share on other sites More sharing options...
bassim Posted August 13, 2014 Author Report Share Posted August 13, 2014 Thanks Man. the fuse was damaged. They got it replaced! Link to comment Share on other sites More sharing options...
