naqaash Posted October 15, 2014 Share Posted October 15, 2014 What does it mean by CV joints in Front wheel drive cars? Link to comment Share on other sites More sharing options...
SIDDIQUI AHMED Posted July 21, 2019 Share Posted July 21, 2019 Drive Shaft Axle Link to comment Share on other sites More sharing options...
Gaurav Posted July 21, 2019 Share Posted July 21, 2019 It's called Constant Velocity Joint that turn your wheel from engine power coming through this drive shaft. Rubber boot is holding the grease inside so the CV joint always move with enough lubrication inside. Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Frederic Posted July 21, 2019 Share Posted July 21, 2019 35 minutes ago, Gaurav said: It's called Constant Velocity Joint that turn your wheel from engine power coming through this drive shaft. Rubber boot is holding the grease inside so the CV joint always move with enough lubrication inside. Rubber boot is also meant to keep dust and sand from entering the unit. "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
shadow79 Posted July 22, 2019 Share Posted July 22, 2019 It's usually the outer one as most of the inners are not serviceable one...when the inner one goes bad then it's better to toss in another one.... Link to comment Share on other sites More sharing options...
