kris Posted December 4, 2014 Report Share Posted December 4, 2014 What are the most common problems faced in the ignition switch? Link to comment Share on other sites More sharing options...
nackjack Posted December 4, 2014 Report Share Posted December 4, 2014 Well I know the following problems: Switch not turning when one insert the key Switch turns but engine doesn’t crank Switch turning, engine cranking but does not start Engine starts and dies in the middle Key does come out even at the OFF position Key get broken inside the switch Link to comment Share on other sites More sharing options...
kris Posted December 5, 2014 Author Report Share Posted December 5, 2014 Awesome. I think you mentioned almost all the problems by the ignition switch. Good knowledge dude. Thanks for sharing. Link to comment Share on other sites More sharing options...
tenace Posted April 19, 2015 Report Share Posted April 19, 2015 "Switch turning, engine cranking but does not start" This is something I have experienced and after a while you want hear the engine cranking at all. This is the time when you need to fix the ignition Link to comment Share on other sites More sharing options...
yanik Posted May 26, 2015 Report Share Posted May 26, 2015 Since this part of the vehicle consists of many elements it can be any of these elements that is causing a problem. The good news is that they are not very expensive. Link to comment Share on other sites More sharing options...
