CadillacDxb Posted May 8, 2012 Share Posted May 8, 2012 Cadillac Manufacturer Codes Cadillac Powertrain Trouble Code List P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1 P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1 P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1 P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2 P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2 P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1 P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1 P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1 P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2 P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2 P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2 P0100 - MAF Sensor Circuit Insufficient Activity P0101 - Mass Air Flow (MAF) Sensor Performance P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency P0104 - Mass Air Flow Circuit Intermittent P0105 - MAP Sensor Circuit Insufficient Activity P0106 - Manifold Absolute Pressure (MAP) System Performance P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage P0109 - Manifold Absolute Pressure Circuit Intermittent P0110 - Intake Air Temperature (IAT) Sensor Circuit P0111 - Intake Air Temperature (IAT) Sensor Performance P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage P0114 - Intake Air Temperature Circuit Intermittent P0115 - Engine Coolant Temperature (ECT) Sensor Circuit P0116 - Engine Coolant Temperature (ECT) Sensor Performance P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage P0119 - Engine Coolant Temperature Circuit Intermittent P0120 - TP System Performance P0121 - TP Sensor Circuit Insufficient Activity P0122 - Throttle Position (TP) Sensor Circuit Low Voltage P0123 - Throttle Position (TP) Sensor Circuit High Voltage P0124 - Throttle Position Sensor 1 Circuit Intermittent P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control P0126 - Insufficient ECT for Stable Operation P0128 - Coolant Thermostat Below Thermostat Regulating Temperature P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1 P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1 P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1 P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1 P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2 P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2 P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2 P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2 P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2 P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3 P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3 P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3 P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3 P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3 P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1 P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1 P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1 P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1 P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1 P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1 P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2 P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2 P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2 P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2 P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2 P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2 P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3 P0169 - Fuel Composition Sensor P0170 - Fuel Trim Bank 1 P0171 - Fuel Trim System Lean Bank 1 P0172 - Fuel Trim System Rich Bank 1 P0173 - Fuel Trim Bank 2 P0174 - Fuel Trim System Lean Bank 2 P0175 - Fuel Trim System Rich Bank 2 P0176 - Fuel Composition Sensor Circuit P0177 - Fuel Composition Sensor Circuit Performance P0178 - Fuel Composition Sensor Circuit Low Voltage P0179 - Fuel Composition Sensor Circuit High Voltage P0180 - Fuel Temperature Sensor 1 Circuit P0181 - Fuel Temp. Sensor 1 Circuit Performance P0182 - Fuel Temperature Sensor Circuit Low Voltage P0183 - Fuel Temperature Sensor Circuit High Voltage P0184 - Fuel Temperature Sensor 1 Circuit Intermittent P0185 - Fuel Temperature Sensor 2 Circuit P0186 - Fuel Temp. Sensor 2 Circuit Performance P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage P0188 - Fuel Temperature Sensor 2 Circuit High Voltage P0189 - Fuel Temperature Sensor 2 Circuit Intermittent P0190 - Fuel Rail Pressure Sensor Circuit P0191 - Fuel Rail Pressure Sensor Circuit Performance P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage P0193 - Fuel Rail Pressure Sensor Circuit High Voltage P0194 - Fuel Rail Pressure Sensor Circuit Intermittent P0195 - Engine Oil Temperature Sensor P0196 - Engine Oil Temperature Sensor Performance P0197 - Engine Oil Temperature Sensor Low Voltage P0198 - Engine Oil Temperature Sensor High Voltage P0199 - Engine Oil Temperature Sensor Intermittent P0200 - Injector Control Circuit P0201 - Injector 1 Control Circuit P0202 - Injector 2 Control Circuit P0203 - Injector 3 Control Circuit P0204 - Injector 4 Control Circuit P0205 - Injector 5 Control Circuit P0206 - Injector 6 Control Circuit P0207 - Injector 7 Control Circuit P0208 - Injector 8 Control Circuit P0209 - Injector 9 Control Circuit P0210 - Injector 10 Control Circuit P0211 - Injector 11 Control Circuit P0212 - Injector 12 Control Circuit P0213 - Cold Start Injector 1 P0214 - Cold Start Injector 2 P0215 - Engine Shutoff Control Circuit P0216 - Injection Timing Control Circuit P0217 - Engine Overtemp Condition P0218 - Transmission Fluid Overtemperature P0219 - Engine Overspeed Condition P0220 - APP Sensor 2 Circuit P0221 - APP (Throttle Position) Sensor 2 Circuit Performance P0222 - APP (Throttle Position) Sensor 2 Circuit Low Voltage P0223 - APP (Throttle Position) Sensor 2 Circuit High Voltage P0224 - Throttle Position Sensor 2 Intermittent P0225 - APP Sensor 3 Circuit P0226 - APP Sensor 3 Circuit Performance P0227 - APP Sensor 3 Circuit Low Voltage P0228 - APP Sensor 3 Circuit High Voltage P0229 - Throttle Position Sensor 3 Intermittent P0230 - Fuel Pump Relay Control Circuit P0231 - Fuel Pump Feedback Circuit Low Voltage P0232 - Fuel Pump Feedback Circuit High Voltage P0233 - Fuel Pump Secondary Circuit Intermittent P0234 - Turbocharger Engine Overboost Condition P0235 - Turbocharger Boost Sensor 1 Circuit P0236 - Turbocharger Boost System P0237 - Turbocharger Boost Sensor Circuit Low Voltage P0238 - Turbocharger Boost Sensor Circuit High Voltage P0239 - Turbocharger Boost Sensor 2 Circuit P0240 - Turbocharger Boost Sensor 2 Performance P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage P0243 - Turbocharger Wastegate Solenoid 1 P0244 - Turbocharger Wastegate Solenoid 1 Performance P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage P0246 - Turbocharger Wastegate Solenoid 1 High Voltage P0247 - Turbocharger Wastegate Solenoid 2 P0248 - Turbocharger Wastegate Solenoid 2 Performance P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage P0250 - Turbocharger Wastegate Solenoid 2 High Voltage P0251 - Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector) P0252 - Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector) P0253 - Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) P0254 - Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) P0255 - Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) P0256 - Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector) P0257 - Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector) P0258 - Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector) P0259 - Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector) P0260 - Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector) P0261 - Cylinder 1 Injector Circuit Low P0262 - Cylinder 1 Injector Circuit High P0263 - Cylinder 1 Contribution/Balance Fault P0264 - Cylinder 2 Injector Circuit Low P0265 - Cylinder 2 Injector Circuit High P0266 - Cylinder 2 Contribution/Balance Fault P0267 - Cylinder 3 Injector Circuit Low P0268 - Cylinder 3 Injector Circuit High P0269 - Cylinder 3 Contribution/Balance Fault P0270 - Cylinder 4 Injector Circuit Low P0271 - Cylinder 4 Injector Circuit High P0272 - Cylinder 4 Contribution/Balance Fault P0273 - Cylinder 5 Injector Circuit Low P0274 - Cylinder 5 Injector Circuit High P0275 - Cylinder 5 Contribution/Balance Fault P0276 - Cylinder 6 Injector Circuit Low P0277 - Cylinder 6 Injector Circuit High P0278 - Cylinder 6 Contribution/Balance Fault P0279 - Cylinder 7 Injector Circuit Low P0280 - Cylinder 7 Injector Circuit High P0281 - Cylinder 7 Contribution/Balance Fault P0282 - Cylinder 8 Injector Circuit Low P0283 - Cylinder 8 Injector Circuit High P0284 - Cylinder 8 Contribution/Balance Fault P0285 - Cylinder 9 Injector Circuit Low P0286 - Cylinder 9 Injector Circuit High P0287 - Cylinder 9 Contribution/Balance Fault P0288 - Cylinder 10 Injector Circuit Low P0289 - Cylinder 10 Injector Circuit High P0290 - Cylinder 10 Contribution/Balance Fault P0291 - Cylinder 11 Injector Circuit Low P0292 - Cylinder 11 Injector Circuit High P0293 - Cylinder 11 Contribution/Balance Fault P0294 - Cylinder 12 Injector Circuit Low P0295 - Cylinder 12 Injector Circuit High P0296 - Cylinder 12 Contribution/Range Fault P0300 - Engine Misfire Detected P0301 - Cylinder 1 Misfire Detected P0302 - Cylinder 2 Misfire Detected P0303 - Cylinder 3 Misfire Detected P0304 - Cylinder 4 Misfire Detected P0305 - Cylinder 5 Misfire Detected P0306 - Cylinder 6 Misfire Detected P0307 - Cylinder 7 Misfire Detected P0308 - Cylinder 8 Misfire Detected P0309 - Cylinder 9 Misfire Detected P0310 - Cylinder 10 Misfire Detected P0311 - Cylinder 11 Misfire Detected P0312 - Cylinder 12 Misfire Detected P0313 - Misfire Detected With Low Fuel Level P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory P0318 - Rough Road Sensor Circuit P0320 - Ignition/Distributor Engine Speed Input Circuit Malfunction P0321 - Ignition/Distributor Engine Speed Input Circuit Range/Performance P0322 - IC Module 4X Reference Circuit No Frequency P0323 - Ignition/Distributor Engine Speed Input Circuit Intermittent P0324 - Knock Sensor (KS) Module Performance P0325 - PCM Knock Sensor Circuit P0326 - Knock Sensor Circuit Excessive Spark Retard P0327 - Knock Sensor Circuit Low Voltage P0328 - Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) P0329 - Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor) P0330 - Knock Sensor (KS) Circuit Bank 2 P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2) P0332 - Knock Sensor 2 Circuit Low Input (Bank 2) P0333 - Knock Sensor 2 Circuit High Input (Bank 2) P0334 - Knock Sensor 2 Circuit Intermittent (Bank 2) P0335 - CKP Sensor A Circuit Performance P0336 - Crankshaft Position (CKP) Sensor A Performance P0337 - Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle P0338 - Crankshaft Position (CKP) Sensor Circuit High Duty Cycle P0339 - Crankshaft Position (CKP) Sensor Circuit Intermittent P0340 - Camshaft Position (CMP) Sensor Circuit P0341 - Camshaft Position (CMP) Sensor Performance P0342 - Camshaft Position Sensor Circuit Low Input P0343 - Camshaft Position Sensor Circuit High Input P0344 - Camshaft Position Sensor Circuit Intermittent P0350 - Ignition Coil Primary/Secondary Circuit Malfunction P0351 - Ignition Coil 1 Control Circuit P0352 - Ignition Coil 2 Control Circuit P0353 - Ignition Coil 3 Control Circuit P0354 - Ignition Coil 4 Control Circuit P0355 - Ignition Coil 5 Control Circuit P0356 - Ignition Coil 6 Control Circuit P0357 - Ignition Coil 7 Control Circuit P0358 - Ignition Coil 8 Control Circuit P0359 - Ignition Coil I Primary/Secondary Circuit Malfunction P0360 - Ignition Coil J Primary/Secondary Circuit Malfunction P0361 - Ignition Coil K Primary/Secondary Circuit Malfunction P0362 - Ignition Coil L Primary/Secondary Circuit Malfunction P0370 - Timing Reference High Resolution Signal A Malfunction P0371 - IC 24X Reference Circuit Too Many Pulses P0372 - IC 24X Reference Circuit Missing Pulses P0373 - Timing Reference High Resolution Signal A Intermittent/Erratic Pulses P0374 - Timing Reference High Resolution Signal A No Pulses P0375 - Timing Reference High Resolution Signal B Malfunction P0376 - Timing Reference High Resolution Signal B Too Many Pulses P0377 - Timing Reference High Resolution Signal B Too Few Pulses P0378 - Timing Reference High Resolution Signal B Intermittent/Erratic Pulses P0379 - Timing Reference High Resolution Signal B No Pulses P0380 - Glow Plug/Heater Circuit "A" Malfunction P0381 - Glow Plug/Heater Indicator Circuit Malfunction P0382 - Exhaust Gas Recirculation Flow Malfunction P0385 - Crankshaft Position (CKP) Sensor B Circuit P0386 - Crankshaft Position (CKP) Sensor B Performance P0387 - Crankshaft Position Sensor B Circuit Low Input P0388 - Crankshaft Position Sensor B Circuit High Input P0389 - Crankshaft Position Sensor B Circuit Intermittent P0400 - Exhaust Gas Recirculation Flow Malfunction P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient P0402 - Exhaust Gas Recirculation Flow Excessive Detected P0403 - Exhaust Gas Recirculation (EGR) Solenoid Control Circuit P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance P0405 - Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage P0406 - Exhaust Gas Recirculation Sensor A Circuit High P0407 - Exhaust Gas Recirculation Sensor B Circuit Low P0408 - Exhaust Gas Recirculation Sensor B Circuit High P0410 - Secondary Air Injection (AIR) System P0411 - Secondary Air Injection (AIR) System P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 P0413 - Secondary Air Injection System Switching Valve A Circuit Open P0414 - Secondary Air Injection System Switching Valve A Circuit Shorted P0415 - Secondary Air Injection System Switching Valve B Circuit Malfunction P0416 - Secondary Air Injection System Switching Valve B Circuit Open P0417 - Secondary Air Injection System Switching Valve B Circuit Shorted P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 P0419 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2 P0420 - Catalyst System Low Efficiency P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1) P0422 - Catalyst System Low Efficiency Bank 1 P0423 - Heated Catalyst Efficiency Below Threshold (Bank 1) P0424 - Heated Catalyst Temperature Below Threshold (Bank 1) P0430 - Catalyst System Low Efficiency Bank 2 P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2) P0432 - Catalyst System Low Efficiency Bank 2 P0433 - Heated Catalyst Efficiency Below Threshold (Bank 2) P0434 - Heated Catalyst Temperature Below Threshold (Bank 2) P0440 - Evaporative Emission (EVAP) System P0441 - Evaporative Emission Control System Incorrect Purge Flow P0442 - Evaporative Emission (EVAP) System Small Leak Detected P0443 - EVAP Purge Solenoid Valve 1 Control Circuit P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446 - EVAP Vent Solenoid Valve Control System P0447 - Evaporative Emission Control System Vent Control Circuit Open P0448 - Evaporative Emission Control System Vent Control Circuit Shorted P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit P0450 - Fuel Tank Pressure Sensor Circuit P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage P0453 - Fuel Tank Pressure Sensor Circuit High Voltage P0454 - Evaporative Emission Control System Pressure Sensor Intermittent P0455 - Evaporative Emission (EVAP) System Leak Detected P0460 - Fuel Level Sensor Circuit P0461 - Fuel Level Sensor Performance P0462 - Fuel Level Sensor Circuit Low Voltage P0463 - Fuel Level Sensor Circuit High Voltage P0464 - Fuel Level Sensor Circuit Intermittent P0465 - Purge Flow Sensor Circuit Malfunction P0466 - Purge Flow Sensor Circuit Range/Performance P0467 - Purge Flow Sensor Circuit Low Input P0468 - Purge Flow Sensor Circuit High Input P0469 - Purge Flow Sensor Circuit Intermittent P0470 - Exhaust Pressure Sensor Malfunction P0471 - Exhaust Pressure Sensor Range/Performance P0472 - Exhaust Pressure Sensor Low P0473 - Exhaust Pressure Sensor High P0474 - Exhaust Pressure Sensor Intermittent P0475 - Exhaust Pressure Control Valve Malfunction P0476 - Exhaust Pressure Control Valve Range/Performance P0477 - Exhaust Pressure Control Valve Low P0478 - Exhaust Pressure Control Valve High P0479 - Exhaust Pressure Control Valve Intermittent P0480 - Cooling Fan Relay 1 Control Circuit P0481 - Cooling Fan Relay 2 Control Circuit P0482 - Cooling Fan 3 Control Circuit Malfunction P0483 - Cooling Fan Rationality Check Malfunction P0484 - Cooling Fan Circuit Over Current P0485 - Cooling Fan Power/Ground Circuit Malfunction P0496 - Evaporative Emission (EVAP) System Flow During Non-Purge P0500 - Vehicle Speed Sensor (VSS) Circuit P0501 - Vehicle Speed Sensor Range/Performance P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input P0503 - Vehicle Speed Sensor (VSS) Circuit Intermittent P0505 - Idle Control System Malfunction P0506 - Idle Speed Low P0507 - Idle Speed High P0510 - Closed Throttle Position Switch Malfunction P0512 - Start Switch Circuit P0520 - Engine Oil Pressure Sensor/Switch Circuit Malfunction P0521 - Engine Oil Pressure Sensor/Switch Circuit Range/Performance P0522 - Engine Oil Pressure Sensor/Switch Circuit Low Voltage P0523 - Engine Oil Pressure Sensor/Switch Circuit High Voltage P0526 - Cooling Fan Speed Sensor Circuit P0530 - A/C Refrigerant Pressure Sensor Circuit Malfunction P0531 - A/C Refrigerant Pressure Sensor Circuit Range/Performance P0532 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage P0533 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage P0534 - Air Conditioner Refrigerant Charge Loss P0550 - Power Steering Pressure (PSP) Switch Circuit P0551 - Power Steering Pressure Sensor Circuit Range/Performance P0552 - Power Steering Pressure Sensor Circuit Low Input P0553 - Power Steering Pressure Sensor Circuit High Input P0554 - Power Steering Pressure Sensor Circuit Intermittent P0560 - System Voltage P0561 - System Voltage Unstable P0562 - System Voltage Low P0563 - System Voltage High P0565 - Cruise Control On Signal Malfunction P0566 - Cruise Control Off Signal Malfunction P0567 - Cruise Control Resume Signal Malfunction P0568 - Cruise Control Set Signal Malfunction P0569 - Cruise Control Coast Signal Malfunction P0570 - Cruise Control Accel Signal Malfunction P0571 - Cruise Control Brake Switch Circuit P0573 - Cruise Control/Brake Switch A Circuit High P0574 - Vehicle Speed Too High - above 110 mph - Cruise Control Disabled P0575 - Cruise Control Related Malfunction P0576 - Cruise Control Related Malfunction P0576 - Cruise Control Related Malfunction P0578 - Cruise Control Related Malfunction P0579 - Cruise Control Related Malfunction P0580 - Cruise Control Related Malfunction P0600 - Serial Communication Link Malfunction P0601 - Control Module Read Only Memory (ROM) P0602 - Control Module Not Programmed P0603 - Control Module Long Term Memory Reset P0604 - Control Module Random Access Memory (RAM) P0605 - Control Module Programming Read Only Memory (ROM) P0606 - Control Module Internal Performance P0607 - ECU Malfunction P0608 - Control Module VSS Output "A" Malfunction P0609 - Control Module VSS Output "B" Malfunction P0610 - Control Module Vehicle Options Incorrect P0615 - Starter Relay Control Circuit P0616 - Starter Relay Control Circuit Low Voltage P0617 - Starter Relay Control Circuit High Voltage P0620 - Generator Control Circuit Malfunction P0621 - Generator L-Terminal Circuit P0622 - Generator F-Terminal Circuit P0625 - Generator F-Terminal Circuit Low Voltage P0626 - Generator F-Terminal Circuit High Voltage P0628 - Fuel Pump Relay Control Circuit Low Voltage P0629 - Fuel Pump Relay Control Circuit High Voltage P0638 - Throttle Actuator Control (TAC) Command Performance P0641 - PCM voltage out of tolerance condition on the 5-volt reference circuit P0645 - Air Conditioning (A/C) Clutch Relay Control Circuit P0646 - Air Conditioning (A/C) Clutch Relay Control Circuit P0647 - Air Conditioning (A/C) Clutch Relay Control Circuit P0650 - Malfunction Indicator Lamp (MIL) Control Circuit P0651 - PCM voltage out of tolerance condition on the 5-volt reference circuit P0654 - Engine RPM Output Circuit Malfunction P0655 - Engine Hot Lamp Output Control Circuit Malfucntion P0656 - Fuel Level Output Circuit Malfunction P0660 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit P0661 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage P0662 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage P0691 - Cooling Fan Relay Control Circuit Low Voltage P0693 - Cooling Fan Relay Control Circuit Low Voltage P0692 - Cooling Fan Relay Control Circuit High Voltage P0694 - Cooling Fan Relay Control Circuit High Voltage P0700 - Transmission Control System Malfunction P0701 - Transmission Control System Range/Performance P0702 - Transmission Control System Electrical P0703 - Brake Switch Circuit Malfunction P0704 - Clutch Switch Input Circuit Malfunction P0705 - Trans Range Switch Circuit P0706 - Trans Range Switch Performance P0707 - Transmission Range Sensor Circuit Low Input P0708 - Transmission Range Sensor Circuit High Input P0709 - Transmission Range Sensor Circuit Intermittent P0710 - Transmission Fluid Temperature Sensor Circuit Malfunction P0711 - TFT Sensor Circuit Range/Performance P0712 - Transmission Fluid Temperature (TFT) Sensor Circuit Low Input P0713 - Transmission Fluid Temperature (TFT) Sensor Circuit High Input P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent P0715 - Input/Turbine Speed Sensor Circuit Malfunction P0716 - Input Speed Sensor Circuit Intermittent P0717 - Input Speed Sensor Circuit Low Input P0718 - Input/Turbine Speed Sensor Circuit Intermittent P0719 - Brake Switch Circuit Low Input P0720 - Output Speed Sensor Circuit Malfunction P0721 - Output Speed Sensor Range/Performance P0722 - Output Speed Sensor Circuit Low Input P0723 - Output Speed Sensor Intermittent P0724 - Brake Switch Circuit High Input P0725 - Engine Speed Input Circuit P0726 - Engine Speed Input Circuit Range/Performance P0727 - Engine Speed Circuit No Signal P0728 - Engine Speed Input Circuit Intermittent P0730 - Incorrect Gear Ratio P0731 - Incorrect 1st Gear Ratio P0732 - Incorrect 2nd Gear Ratio P0733 - Incorrect 3rd Gear Ratio P0734 - Incorrect 4th Gear Ratio P0735 - Gear 5 Incorrect ratio P0736 - Reverse incorrect gear ratio P0740 - TCC Enable Solenoid Circuit Electrical P0741 - TCC System Stuck Off P0742 - TCC System Stuck On P0743 - TCC Enable Solenoid Circuit Electrical P0744 - Torque Converter Clutch Circuit Intermittent P0745 - Pressure Control Solenoid Malfunction P0746 - Pressure Control Solenoid Performance or Stuck Off P0747 - Pressure Control Solenoid Stuck On P0748 - Pressure Control Solenoid Circuit Electrical P0749 - Pressure Control Solenoid Intermittent P0750 - Shift Solenoid A Malfunction P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear P0752 - 1-2 Shift Solenoid Valve Performance - No Second or Third Gear P0753 - 1-2 Shift Solenoid Circuit Electrical P0754 - Shift Solenoid A Intermittent P0755 - Shift Solenoid B Malfunction P0756 - 2-3 Shift Solenoid Valve Performance - No First or Second Gear P0757 - 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear P0758 - 2-3 Shift Solenoid Circuit Electrical P0759 - Shift Solenoid B Intermittent P0760 - Shift Solenoid C Malfunction P0761 - Shift Solenoid C Performance or Stuck Off P0762 - Shift Solenoid C Stuck On P0763 - Shift Solenoid C Electrical P0764 - Shift Solenoid C Intermittent P0765 - Shift Solenoid D Malfunction P0766 - Shift Solenoid D Performance or Stuck Off P0767 - Shift Solenoid D Stuck On P0768 - Shift Solenoid D Electrical P0769 - Shift Solenoid D Intermittent P0770 - Shift Solenoid E Malfunction P0771 - Shift Solenoid E Performance or Stuck Off P0772 - Shift Solenoid E Stuck On P0773 - Shift Solenoid E Electrical P0774 - Shift Solenoid E Intermittent P0780 - Shift Malfunction P0781 - 1-2 Shift Malfunction P0782 - 2-3 Shift Malfunction P0783 - 3-4 Shift Malfunction P0784 - 4-5 Shift Malfunction P0785 - 3-2 Shift Solenoid Circuit Electrical P0786 - Shift/Timing Solenoid Range/Performance P0787 - Shift/Timing Solenoid Low P0788 - Shift/Timing Solenoid High P0789 - Shift/Timing Solenoid Intermittent P0790 - Normal/Performance Switch Circuit Malfunction P0801 - Reverse Inhibit Control Circuit Malfunction P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction P0850 - Park/Neutral Position (PNP) Switch Circuit P0856 - Powertrain Indicated Traction Control Malfunction P0894 - Transmission Component Slipping P0897 - PCM detects a calculated transmission fluid life of 10 percent or less P0973 - PCM detects an open or short to ground in the 1-2 SS valve circuit P0974 - PCM detects a continuous short to voltage in the 1-2 SS valve circuit P0976 - PCM detects a continuous open or short to ground in the 2-3 SS valve circuit P0977 - PCM detects a continuous short to voltage in the 2-3 SS valve circuit P1031 - Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1 P1032 - Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1 P1101 - Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow P1105 - Secondary Vacuum Sensor Circuit P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage P1107 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage P1108 - BARO to MAP Sensor Comparison Too High P1109 - Secondary Port Throttle System P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage P1112 - Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage P1113 - Intake Resonance Switchover Solenoid Control Circuit P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage P1115 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage P1116 - ECT Signal Unstable or Intermittent P1117 - Engine Coolant Temp. Signal Out-Of-Range Low P1118 - Engine Coolant Temp. Signal Out-Of-Range High P1119 - ECT Signal Out-Of-Range With TFT Sensor P1120 - Throttle Position (TP) Sensor 1 Circuit P1121 - Throttle Position (TP) Sensor Circuit Intermittent High Voltage P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage P1125 - Accelerator Pedal Position (APP) System P1130 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1 P1131 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2 P1132 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1 P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1 P1134 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1 P1135 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1 P1136 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1 P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage P1138 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage P1139 - Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2 P1140 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2 P1141 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 P1143 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage P1144 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage P1145 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3 P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1 P1154 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1 P1155 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1 P1156 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1 P1157 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage P1158 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage P1159 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2 P1161 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2 P1163 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage P1164 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage P1165 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3 P1170 - Bank to Bank Fuel Trim Offset P1171 - Fuel System Lean During Acceleration P1172 - Fuel Transfer Pump Flow Insufficient P1185 - Engine Oil Temperature Circuit P1186 - EOT Circuit Performance P1187 - EOT Sensor Circuit Low Voltage P1188 - EOT Sensor Circuit High Voltage P1189 - Engine Oil Pressure (EOP) Switch Circuit P1190 - Engine Vacuum Leak P1191 - Intake Air Duct Air Leak P1200 - Injector Control Circuit P1201 - (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance P1202 - (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency P1203 - (Alt. Fuel) Gas Mass Sensor Circuit High Frequency P1211 - Mass Air Flow Circuit Intermittent High P1212 - Mass Air Flow Circuit Intermittent Low P1214 - Injection Pump Timing Offset P1215 - Ground Fault Detection Indicated P1216 - Fuel Solenoid Response Time Too Short P1217 - Fuel Solenoid Response Time Too Long P1218 - Injection Pump Calibration Circuit P1219 - Throttle Position Sensor Reference Voltage P1220 - Throttle Position (TP) Sensor 2 Circuit P1221 - Fuel Pump Secondary Circuit Low P1222 - Injector Control Circuit Intermittent P1225 - Injector Circuit Cylinder 2 Intermittent P1228 - Injector Circuit Cylinder 3 Intermittent P1231 - Injector Circuit Cylinder 4 Intermittent P1234 - Injector Circuit Cylinder 5 Intermittent P1237 - Injector Circuit Cylinder 6 Intermittent P1240 - Injector Circuit Cylinder 7 Intermittent P1243 - Injector Circuit Cylinder 8 Intermittent P1245 - Intake Plenum Switchover Valve P1250 - Early Fuel Evaporation Heater Circuit P1257 - Supercharger System Overboost P1258 - Engine Coolant Overtemperature - above 268°F - Protection Mode Active P1260 - Last Test Failed Failed SCC ENTER:More Info. P1270 - Accelerator Pedal Position Sensor A/D Converter Error P1271 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation P1272 - Accelerator Pedal Position Sensor 2 P1273 - "Accelerator Pedal Position Sensor 1 P1274 - Injectors Wired Incorrectly P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit P1276 - Accelerator Pedal Position Sensor 1 Circuit Performance P1277 - Accelerator Pedal Position Sensor 1 Circuit Low Voltage P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage P1280 - Accelerator Pedal Position (APP) Sensor 2 Circuit P1281 - Accelerator Pedal Position Sensor 2 Circuit Performance P1282 - Accelerator Pedal Position Sensor 2 Circuit Low Voltage P1283 - Accelerator Pedal Position Sensor 2 Circuit High Voltage P1285 - Accelerator Pedal Position Sensor 3 Circuit P1286 - Accelerator Pedal Position Sensor 3 Circuit Performance P1287 - Accelerator Pedal Position Sensor 3 Circuit Low Voltage P1288 - Accelerator Pedal Position Sensor 3 Circuit High Voltage P1300 - Ignitor Circuit P1305 - Ignition Coil 2 Primary Feedback Circuit P1310 - Ignition Coil 3 Primary Feedback Circuit P1315 - Ignition Coil 4 Primary Feedback Circuit P1320 - IC 4X Reference Circuit Intermittent P1321 - Electronic Ignition System Fault Line P1322 - EI System or Ignition Control Extra or Missing P1323 - IC 24X Reference Circuit Low Frequency P1324 - Crank RPM Too Low P1335 - CKP Circuit P1336 - Crankshaft Position (CKP) System Variation Not Learned P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation P1346 - Intake Camshaft Position [CMP] Sensor System Performance P1350 - Ignition Control System P1351 - Ignition Coil Control Circuit High Voltage P1352 - IC Output High/Pulse Detected when GND_Cyl. 2 P1353 - IC Output High/Pulse Detected when GND_Cyl. 3 P1354 - IC Output High/Pulse Detected when GND_Cyl. 4 P1355 - IC Output High/Pulse Detected when GND_Cyl. 5 P1356 - IC Output High/Pulse Detected when GND_Cyl. 6 P1357 - IC Output High/Pulse Detected when GND_Cyl. 7 P1358 - IC Output High/Pulse Detected when GND_Cyl. 8 P1359 - Ignition Coil Group 1 Control Circuit P1360 - Ignition Coil Group 2 Control Circuit P1361 - Ignition Coil Control Circuit Low Voltage P1362 - IC Cylinder 2 Not Toggling After Enable P1363 - IC Cylinder 3 Not Toggling After Enable P1364 - IC Cylinder 4 Not Toggling After Enable P1365 - IC Cylinder 5 Not Toggling After Enable P1366 - IC Cylinder 6 Not Toggling After Enable P1367 - IC Cylinder 7 Not Toggling After Enable P1368 - IC Cylinder 8 Not Toggling After Enable P1370 - IC 4X Reference Circuit Too Many Pulses P1371 - IC 4X Reference Circuit Too Few Pulses P1372 - Crankshaft Position (CKP) Sensor A-B Correlation P1374 - 3X Reference Circuit P1375 - IC 24X Reference Circuit High Voltage P1376 - Ignition Ground Circuit P1377 - IC Cam Pulse To 4X Reference Pulse P1380 - Misfire Detected - Rough Road Data Not Available P1381 - Misfire Detected - No Communication with Brake Control Module P1390 - Wheel Speed Sensor 1 - G - Sensor Circuit P1391 - Wheel Speed Sensor 1 - G - Sensor Circuit Performance P1392 - Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage P1393 - Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage P1394 - Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent P1395 - Wheel Speed Sensor 2 - G - Sensor Circuit P1396 - Wheel Speed Sensor 2 - G - Sensor Circuit Performance P1397 - Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage P1398 - Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage P1399 - Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent P1403 - Exhaust Gas Recirculation System Valve 1 P1404 - Exhaust Gas Recirculation (EGR) Closed Position Performance P1405 - Exhaust Gas Recirculation System Valve 3 P1406 - EGR Valve Pintle Position Circuit P1407 - EGR Air Intrusion in Exhaust Supply to EGR Valve P1408 - Intake Manifold Pressure Sensor Circuit P1409 - EGR Vacuum System Leak P1410 - Fuel Tank Pressure System P1415 - Secondary Air Injection (AIR) System Bank 1 P1416 - Secondary Air Injection (AIR) System Bank 2 P1418 - Secondary Air Injection System Relay A Control Circuit High P1420 - Intake Air Low Pressure Switch Circuit Low Voltage P1421 - Intake Air Low Pressure Switch Circuit High Voltage P1423 - Intake Air High Pressure Switch Circuit High Voltage P1431 - Fuel Level Sensor 2 Circuit Performance P1432 - Fuel Level Sensor 2 Circuit Low Voltage P1433 - Fuel Level Sensor 2 Circuit High Voltage P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge P1442 - EVAP Vacuum Sw. High Voltage During Ign. On P1450 - Barometric Pressure Sensor Circuit P1451 - Barometric Press. Sensor Performance P1460 - Cooling Fan Control System P1480 - Cooling Fan 1 Control Circuit High P1481 - Cooling Fan Speed Sensor Circuit P1482 - Cooling Fan Speed Output Circuit P1483 - Engine Cooling System Performance P1484 - Cooling Fan System Performance P1500 - Starter Signal Circuit P1501 - Theft Deterrent System P1501 - Vehicle Speed Sensor Circuit Intermittent P1502 - Theft Deterrent Fuel Enable Signal Not Received P1503 - Theft Deterrent Fuel Enable Signal Not Correct P1504 - Vehicle Speed Output Circuit P1508 - Idle Speed Low - Idle Air Control (IAC) System Not Responding P1509 - Idle Speed High - Idle Air Control (IAC) System Not Responding P1510 - Throttle Control System Performance - Throttle Limitation Active P1511 - Throttle Control System - Backup System Performance P1514 - Airflow to TP Sensor Correlation High P1515 - Electronic Throttle System Throttle Position P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance P1517 - Electronic Throttle Module P1518 - Electronic Throttle Module to PCM Communication P1519 - Throttle Actuator Control (TAC) Module Internal Circuit P1520 - Transmission Range Switch Circuit P1521 - Transmission Engaged at High Throttle Angle P1522 - Park/Neutral to Drive/Reverse at High RPM P1523 - Throttle Closed Position Performance P1524 - Throttle Closed Position Performance P1525 - Throttle Body ServiceRequired P1526 - Minimum Throttle Position Not Learned P1527 - Transmission Range to Pressure Switch Correlation P1528 - Governor P1529 - Heated Windshield Request Problem P1530 - Throttle Actuator Control (TAC) Module Internal Circuit P1531 - A/C Low Side Temperature Sensor Fault P1532 - A/C Evaporator Temp. Sens. Circuit Low Voltage P1533 - A/C Evaporator Temp. Sens. Circuit High Voltage P1534 - A/C High Side Temp. Sensor Low Voltage P1535 - A/C High Side Temperature Sensor Circuit P1536 - Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled P1537 - A/C Request Circuit Low Voltage P1538 - A/C Request Circuit High Voltage P1539 - A/C Clutch Status Circuit High Voltage P1540 - Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled P1541 - A/C High Side Over Temperature P1542 - A/C System High Pressure High Temperature P1543 - A/C System Performance P1544 - A/C Refrigerant Condition Very Low P1545 - Air Conditioning (A/C) Clutch Relay Control Circuit P1546 - A/C Clutch Status Circuit Low Voltage P1547 - A/C System Performance Degraded P1548 - A/C Recirculation Circuit P1551 - Throttle Valve Rest Position Not Reached During Learn P1554 - Cruise Control Feedback Circuit P1555 - Electronic Variable Orifice Output P1558 - Cruise Control Servo Indicates Low P1559 - Cruise Control Power Management Mode P1560 - Transaxle Not in Drive - Cruise Control Disabled P1561 - Cruise Vent Solenoid P1562 - Cruise Vacuum Solenoid P1563 - Cruise Vehicle Speed/Set Speed Difference Too High P1564 - Vehicle Acceleration Too High - Cruise Control Disabled P1565 - Cruise Servo Position Sensor P1566 - Engine RPM Too High - Cruise Control Disabled P1567 - Active Banking Control Active - Cruise Control Disabled P1568 - Cruise Servo Stroke Greater than Commanded in Cruise P1569 - Cruise Servo Stroke High While not in Cruise P1570 - Traction Control Active - Cruise Control Disabled P1571 - Traction Control Torque Request Circuit P1572 - ASR Active Circuit Low Too Long P1573 - PCM/EBTCM Serial Data Circuit P1574 - Stoplamp Switch Circuit P1575 - Extended Travel Brake Switch Circuit P1576 - BBV Sensor Circuit High Voltage P1577 - BBV Sensor Circuit Low Voltage P1578 - BBV Sensor Circuit Low Vacuum P1579 - P/N to D/R at High Throttle Angle - Power Reduction Mode Active P1580 - Cruise Move Circuit Low Voltage P1581 - Cruise Move Circuit High Voltage P1582 - Cruise Direction Circuit Low Voltage P1583 - Cruise Direction CircuitHigh Voltage P1584 - Cruise Control Disabled P1585 - Cruise Control Inhibit Output Circuit P1586 - Cruise Control Brake Switch 2 Circuit P1587 - Cruise Control Clutch Control Circuit Low P1588 - Cruise Control Clutch Control Circuit High P1599 - Engine Stall or Near Stall Detected P1600 - TCM Internal Watchdog Operation P1601 - Serial Comm. Problem With Device 1 P1602 - Knock Sensor (KS) Module Performance P1603 - Loss of SDM Serial Data P1604 - Loss of IPC Serial Data P1605 - Loss of HVAC Serial Data P1606 - Serial Communication Problem With Device 6 P1607 - Serial Communication Problem With Device 7 P1608 - Serial Communication Problem With Device 8 P1609 - Loss Of TCS Serial Data P1610 - Loss of PZM Serial Data P1611 - Loss of CVRTD Serial Data P1612 - Loss of IPM Serial Data P1613 - Loss of DIM Serial Data P1614 - Loss of RIM Serial Data P1615 - Loss of VTD Serial Data P1617 - Engine Oil Level Switch Circuit P1619 - Engine Oil Life Monitor Reset Circuit P1620 - Low Coolant Circuit P1621 - Control Module Long Term Memory Performance P1622 - Cylinder Select P1623 - Transmission Temp Pull-Up Resistor P1624 - Customer Snapshot Requested - Data Available P1625 - TCM System Reset P1626 - Theft Deterrent Fuel Enable Signal Not Received P1627 - A/D Performance P1628 - ECT Pull-Up Resistor P1629 - Theft Deterrent System - Cranking Signal P1630 - Theft Deterrent Learn Mode Active P1631 - Theft Deterrent Start Enable Signal Not Correct P1632 - Theft Deterrent Fuel Disable Signal Received P1633 - Ignition 0 Switch Circuit P1634 - Ignition 1 Switch Circuit P1635 - 5 Volt Reference Circuit P1636 - PCM Stack Overrun P1637 - Generator L-Terminal Circuit P1638 - Generator F-Terminal Circuit P1639 - 5 Volt Reference 2 Circuit P1640 - Driver-1-Input High Voltage P1641 - Malfunction Indicator Lamp (MIL) Control Circuit P1642 - Vehicle Speed Output Circuit P1643 - Engine Speed Output Circuit P1644 - Traction Control Delivered Torque Output Circuit P1645 - Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit P1646 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit P1647 - Driver 1 Line 7 P1650 - Control Module Output B Circuit P1651 - Fan 1 Relay Control Circuit P1652 - Powertrain Induced Chassis Pitch Output Circuit P1653 - Oil Level Lamp Control Circuit P1654 - Cruise Control Inhibit Output Circuit P1655 - EVAP Purge Solenoid Control Circuit P1656 - Driver 2 Line 6 P1657 - 1-4 Upshift Solenoid Control Circuit P1658 - Starter Enable Relay Control Circuit P1660 - Cooling Fan Control Circuits P1661 - MIL Control Circuit P1662 - Cruise Lamp Control Circuit P1663 - Oil Life Lamp Control Circuit P1664 - 1-4 Upshift Lamp Control Circuit P1665 - Driver 3 Line 5 P1666 - Driver 3 Line 6 P1667 - Reverse Inhibit Solenoid Control Circuit P1669 - ABS Unit Expected P1670 - Driver 4 P1671 - Driver 4 Line 1 P1672 - Low Engine Oil Level Lamp Control Circuit P1673 - Engine Hot Lamp Control Circuit P1674 - Tachometer Control Circuit P1675 - EVAP Vent Solenoid Control Circuit P1676 - Driver 4 Line 6 P1677 - Driver 4 Line 7 P1680 - Driver 5 P1681 - Driver 5 Line 1 P1682 - Driver 5 Line 2 P1683 - Driver 5 Line 3 P1684 - Driver 5 Line 4 P1685 - Driver 5 Line 5 P1686 - Driver 5 Line 6 P1687 - Driver 5 Line 7 P1689 - Delivered Torque Circuit Fault P1690 - ECM Loop Overrun P1691 - Coolant Gage Circuit Low Voltage P1692 - Coolant Gage Circuit High Voltage P1693 - Tachometer Circuit Low Voltage P1694 - Tachometer Circuit High Voltage P1695 - Remote Keyless Entry Circuit Low P1696 - Remote Keyless Entry Voltage High P1700 - Transmission Control Module (TCM) Requested MIL Illumination P1701 - Trans. MIL Request Circuit P1705 - P/N Signal Output Circuit P1740 - Torque Reduction Signal Circuit P1743 - TP Signal from ECM P1760 - TCM Supply Voltage Interrupted P1779 - Engine Torque Delivered to TCM Signal P1780 - Park/Neutral Position [PNP] Switch Circuit P1781 - Engine Torque Signal Circuit P1790 - Transmission Control Module Checksum P1791 - Transmission Control Module Loop P1791 - Throttle/Pedal Position Signal (2000+) P1792 - Transmission Control Module Reprogrammable Memory P1792 - ECM to TCM Engine Coolant Signal P1793 - Transmission Control Module Stack Overrun P1793 - Wheel Speed Signal (2000+) P1795 - CAN Bus - Throttle Body Position P1800 - TCM Power Relay Control Circuit P1801 - Performance Selector Switch Failure P1804 - Ground Control Relay P1810 - TFP Valve Position Switch Circuit P1811 - Maximum Adapt and Long Shift P1812 - Transmission Over Temperature Condition P1813 - Torque Control P1814 - Torque Converter Overstressed P1815 - Transmission Range Switch - Start In Wrong Range P1816 - TFP Valve Position Sw. - Park/Neu. With Drive Ratio P1817 - TFP Valve Position Sw. - Reverse With Drive Ratio P1818 - TFP Valve Position Sw. - Drive Without Drive Ratio P1819 - Internal Mode Switch - No Start\Wrong Range P1820 - Internal Mode Switch Circuit A Low P1822 - Internal Mode Switch Circuit B High P1823 - Internal Mode Switch Circuit P Low P1825 - Internal Mode Switch - Invalid Range P1826 - Internal Mode Switch Circuit C - High P1831 - Pressure Control (PC) Solenoid Power Circuit - Low Voltage P1832 - Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage P1833 - A/T Solenoids Power Circuit - Low Voltage P1834 - Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage P1835 - Kick-Down Switch Circuit P1836 - Kick-Down Switch Failed Open P1837 - Kick-Down Switch Failed Short P1842 - 1-2 Shift Solenoid Circuit Low Voltage P1843 - 1-2 Shift Solenoid Circuit High Voltage P1844 - Torque Reduction Signal Circuit Desired By TCM P1845 - 2-3 Shift Solenoid Circuit Low Voltage P1847 - 2-3 Shift Solenoid Circuit High Voltage P1850 - Brake Band Apply Solenoid Circuit P1851 - Brake Band Apply Solenoid Performance P1852 - Brake Band Apply SolenoidLow Voltage P1853 - Brake Band Apply Solenoid High Voltage P1860 - TCC PWM Solenoid Circuit Electrical P1864 - Torque Converter Clutch Circuit P1865 - 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage P1866 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage P1867 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage P1868 - Transmission Fluid Life P1870 - Transmission Component Slipping P1871 - Undefined Gear Ratio P1873 - TCC Stator Temp. Switch Circuit Low P1874 - TCC Stator Temp. Switch Circuit High P1875 - 4WD Low Switch Circuit Electrical P1884 - TCC Enable/Shift Light Circuit P1886 - Shift Timing Solenoid P1887 - TCC Release Switch Circuit P1890 - ECM Data Input Circuit P1890 - Throttle Position Signal Input P1891 - Throttle Position Sensor PWM Signal Low P1892 - Throttle Position Sensor PWM Signal High P1893 - Engine Torque Signal Low Voltage P1894 - Engine Torque Signal High Voltage P1895 - TCM to ECM Torque Reduction Circuit P2008 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit P2009 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage P2010 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage P2066 - Fuel Level Sensor 2 Performance P2067 - Fuel Level Sensor 2 Circuit Low Voltage P2068 - Fuel Level Sensor 2 Circuit High Voltage P2096 - Post Catalyst Fuel Trim System Low Limit P2097 - Post Catalyst Fuel Trim System High Limit P2098 - Post Catalyst Fuel Trim System Low Limit P2099 - Post Catalyst Fuel Trim System High Limit P2100 - Throttle Actuator Control (TAC) Motor Control Circuit P2101 - Control Module Throttle Actuator Position Performance P2105 - Throttle Actuator Control (TAC) System - Forced Engine Shutdown P2107 - Throttle Actuator Control (TAC) Module Internal Circuit P2108 - Throttle Actuator Control (TAC) Module Performance P2119 - Throttle Closed Position Performance P2120 - Accelerator Pedal Position (APP) Sensor 1 Circuit P2121 - Accelerator Pedal Position (APP) Sensor 1 Performance P2122 - Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage P2123 - Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage P2125 - Accelerator Pedal Position (APP) Sensor 2 Circuit P2127 - Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage P2128 - Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage P2135 - Throttle Position (TP) Sensor 1-2 Correlation P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation P2176 - Minimum Throttle Position Not Learned P2500 - Generator L-Terminal Circuit Low Voltage P2501 - Generator L-Terminal Circuit High Voltage P2610 - ECU Malfunction P2763 - Short to voltage in the TCC Solenoid P2764 - Open or Short to ground in the TCC PWM solenoid valve circuit P3000 - Hacking AWH Data Link to comment Share on other sites More sharing options...
georgesam Posted May 8, 2012 Share Posted May 8, 2012 really helpful now i wont have to Google the codes. thanks man Link to comment Share on other sites More sharing options...
