Baraz Posted April 7, 2016 Share Posted April 7, 2016 Hi fellas, how you all doing....? I am noticing since few days a random wobbling on certain speeds some times. It's not always so its difficult to say what is causing this.It's a slight wobbling and not too much when you get the with unbalanced tires. Appreciate if someone can way to debug this issue. Link to comment Share on other sites More sharing options...
victor Posted April 8, 2016 Share Posted April 8, 2016 Have you check all the 4 wheels from inside for any presence of sand as this occasional issue often caused by little sand inside the wheel and when circle with the wheel rotation perfectly it doesn't cause any imbalance, but when it rotate in two three places inside the tire then it causes imbalance. Worth removing it off the rim and get it cleaned. 2 Link to comment Share on other sites More sharing options...
Barry Posted April 9, 2016 Share Posted April 9, 2016 Check that one of the balancing weights hasn't fallen off your wheel. 1 Link to comment Share on other sites More sharing options...
Baraz Posted April 9, 2016 Author Share Posted April 9, 2016 Thanks Victor and Technician, I like Technician advise most to visually check first and then go to tire shop and waste my time. Link to comment Share on other sites More sharing options...
