  • 1 year later...
Check the blower fan it must be in a bad shape, also make sure the compressor is fine, that is located with the serpentine belt. sometime it happens with the faulty electrical line (earthing)
  • 6 months later...
Agreed! Make sure that the filter is working fine in your car. I even read an article upon desert driving. the derert climate does affects the AC of the car. So, before entering into desert make sure the compressor of the AC is wired properly. The best thing that you can do is consult a professional and give your car for scanning before going to desert (interior as well as exterior). :)8-)
