Asihraf TP Posted November 25, 2016 Share Posted November 25, 2016 Recently my Galant car started consuming more fuel and appears black smoke on giving raise. Tried changing the air filter, spark plugs cleaned and also injector cleaning liquid applied through fuel tank. Air Flow sensor replaced recently (with a used one) making disappearing the engine check sign and disappearing MAF complaint appearing in computer test. There is fall in rpm on switching on the A/c and has started low pulling occasionally while accelerating from lower speed. Kindly advise if there is someone who can guide me. Thanks Link to comment Share on other sites More sharing options...
brandan Posted November 26, 2016 Share Posted November 26, 2016 Has your car overheated lately? Check your coolant and tell if it's reducing in quantity frequently? Check your engine oil and tell if it's turned milky or have traces of water or coolant? Slimy feel and no longer feel like oil. Link to comment Share on other sites More sharing options...
adil Posted November 26, 2016 Share Posted November 26, 2016 If you already sorted out air filter, injector then cause of black smoke at tailpipe means your car engine running too rich in fuel. Only thing left to check is fuel return lines, as I suspect excessive fuel is not able to return properly and getting forcefully burnt resulting in black smoke. Link to comment Share on other sites More sharing options...
Asihraf TP Posted November 27, 2016 Author Share Posted November 27, 2016 Thank you Mr. Brandan and Mr. Adil for your valuable inputs. Eventhough there was an over heating episode few months back and got rectified (the coolineg system was serviced including the fan), this much overconsumpution was not noted till recent days. The coolant is not reducing in qty. The oil is not giving any abnormal changes noted in the earlier days after changing it. About the return pipe, I am not sure, but technicians were discussing something about that also, which I have no idea what they meant. Kindly comment further if you find some thing more based on the above info above. Thanks Link to comment Share on other sites More sharing options...
