bobby Posted September 24, 2013 Share Posted September 24, 2013 Hi there, today I sat in my SRX like I normally do to drop off my 6 year old son to school and it would not start. I pushed the start button and I could only hear a distant click but nothing more. Well it had to go from bad to worse obviously. The DIC (Driver information center) came up with a couple of warnings, first no remote detected then something else which I don't remember because by then I started to panic. With some help, I actually had to jump start the thing to drive off. Up till now the car is fine but I am scared about what happened this morning. I might have troubles going home from work tonight! Any theories? Link to comment Share on other sites More sharing options...
hunter Posted October 10, 2013 Share Posted October 10, 2013 Get the battery checked at first, more than likely battery is dead. This type of symptom followed with plenty of warning means battery cranking power has depleted and when you try to crank it sucks remaining battery juices and throw all faults and warning light. If battery is fine then it should start of its own and not with jump start. If after that instance battery was fine, i strongly recommend to get the proper OBD II diagnostic done as soon as you can and see what all faults are recorded and why? Link to comment Share on other sites More sharing options...
